XR Gears, Input Shafts, Housing's >
Old 04-18-2016 | 08:14 AM
Default XR Gears, Input Shafts, Housing's
I have two sets of XR gear packs 20hrs+/-. One set has a bad clutch shaft. $600 for set with good clutch shaft, $500 for set with bad shaft.
Two IMCO extension input shafts, need to be cleaned up and painted. $200 each
Two big ujoint XR input assy. with pinion gears, 20hrs+/- $400 each
Two Bravo XR upper housings, don't know the years, with top cap and drive showers. $400 each
All prices are plus the ride, prices a little neg. if you buy in sets. Check or wire, I don't use paypal.
Call or text 252-333-5898
Brad
[ATTACH=CONFIG]554322[/ATTACH][ATTACH=CONFIG]554323[/ATTACH][ATTACH=CONFIG]554324[/ATTACH][ATTACH=CONFIG]554325[/ATTACH][ATTACH=CONFIG]554326[/ATTACH][ATTACH=CONFIG]554327[/ATTACH][ATTACH=CONFIG]554328[/ATTACH]
Attached Thumbnails XR Gears, Input Shafts, Housing's-027.jpg   XR Gears, Input Shafts, Housing's-028.jpg   XR Gears, Input Shafts, Housing's-029.jpg
XR Gears, Input Shafts, Housing's-033.jpg   XR Gears, Input Shafts, Housing's-034.jpg   XR Gears, Input Shafts, Housing's-035.jpg
598 Formula is offline
Old 04-18-2016 | 08:37 AM
PM Sent
endeavour32 is offline
Old 04-18-2016 | 09:33 AM
Everything sold except extension shafts, pending payment.
Old 04-19-2016 | 05:25 PM
Imco drive shafts still around? 1.217 cap diameter?
IGetWet is offline
Old 04-19-2016 | 08:32 PM
I can measure them tomorrow
Old 06-02-2016 | 06:25 AM
will buy the long imco input shafts if they are the 1,328 cap dia !
ring210 is offline
