Backfire through carb >
Old 04-23-2016 | 03:40 PM
Default Backfire through carb
Twin 489 strokers. Xm284hr cam. L29 heads. Timing 8 initial. 28 all in. Holley 750 vauum secondaries. One runs great. Other gets to 3000 rpm and backfires. Idle hard to set on that one as well. Was running fine. Changed vacuum spring and jetted up 79p 76s sec-86p 89s Found small tear in vacuum secondary diaprahm but the are not even opening when backfireing occurs. Whats up. 1 hour run time
mggdoors is offline
Old 04-23-2016 | 04:06 PM
is it happening under load? Or just when rev'ing up in nuetral?
MILD THUNDER is offline
Old 04-23-2016 | 04:09 PM
alot of things could be causing this.from carb to 1 or 2 tight lifters or ignition problem.maybe pull plugs and compare them all.
sutphen 30 is offline
Old 04-23-2016 | 04:39 PM
U swap out carbs yet
getrdunn is offline
Happens under load
mggdoors is offline
Old 04-23-2016 | 04:41 PM
No. We were going to but figured we wouldnt be able to turn without power steering
mggdoors is offline
Old 04-23-2016 | 04:44 PM
I have some quickfuel 750 dp sitting for another project we are going to toss on and see if it has the same results
mggdoors is offline
Old 04-23-2016 | 10:20 PM
Quick fiel 750 hr carbs fixed it. Still needs fine tuning Rpm acting weird on port engine. Everything is good to 4k then the port climbs with thtottle but stbd stays. Can hear both revving. Port oil pressure in neutral will raise to 65 at 4k. In gear 40 max. Possible grounding issues? Gaugrs are Ss comp
mggdoors is offline
Old 04-24-2016 | 08:18 AM
I'd put a mechanical oil pressure gauge on and verify pressure.as for the strb engine,,was it the one that was popping?
Old 04-24-2016 | 09:30 AM
Sorry port was was that was popping and wont go up on oil pressure in gear or give consistent rpm
mggdoors is offline
