Prop spinning while on the trailer >
Old 04-25-2016 | 08:24 PM
Default Prop spinning while on the trailer
I was traveling on 94 in Michigan today and was following a bass boat- The engine was down and the air flow past the prop was causing it to spin. My question is - is that really good for the gears??? I know they are in oil (or at least should be) but to have this constant spinning sure seems like not a good thing.
I know on our boat there is no way that I could trailer the boat and have the outdrive down-- so air velocity going by the prop is a non-issue.
Any thoughts??
3pointstar
3pointstar is offline
Old 04-25-2016 | 09:00 PM
maybe after 100 years of that you might see some wear on the gears.
pstorti is offline
Old 04-25-2016 | 09:19 PM
B/W says you can free wheel their transmissions with no damage.
f_inscreenname is offline
Old 04-25-2016 | 09:43 PM
no load and spinning that slow isn't anything compared to real use.
tmmii is offline
Old 04-25-2016 | 09:44 PM
maybe the guy had his boat motor running in gear to improve fuel mileage on the truck and reduce drag
phil_p999 is offline
Old 04-25-2016 | 10:01 PM
I don't see how it could hurt. Not in gear so just spinning bearing in oil.
akaboatman is offline
Old 04-26-2016 | 01:08 AM
It's one of those new Nader Electric outboards. That's how they charge the batteries on the way to the ramp.
zz28zz is offline
Old 04-26-2016 | 08:24 AM
When we have our heavy equipment shipped, we always put a hood over the exhaust stack on the ones with miter cut exhaust stacks....or else depending on how they're on the truck/train, air is forced down the stack, spinning the turbo while it's dry.....cashing the turbo(s).
A prop spinning at 60 rpm out of gear....that won't be a problem.
Wasted Income is offline
Old 04-26-2016 | 09:16 AM
I would be more worried about rock chips on my prop then the gears in the lower unit
turbom700 is offline
