White Scale On Stainless Parts In Salt Water >
Old 04-25-2016 | 08:44 PM
Default White Scale On Stainless Parts In Salt Water
What is the white scale that forms on any bare stainless that sits in salt water or brackish water? Is there anyway to prevent it and what is the best way to clean in when you get it out? Thanks in advance for any help.
Esal is offline
Old 04-26-2016 | 12:04 AM
Its oxidation. If it were regular steel it would be orange color, aka rust. But stainless oxidizes white. To clean, go to smart and final, get their stainless steel cleaner for restaurants and STAINLESS steel wool. we use it all the time in the restaurant kitchens, and on my boat. Don't use regular steel wool, it will leave small particles that causes rust specs.
DMOORE is offline
Old 04-26-2016 | 06:16 AM
It's white death
At this point just pull the drain plug and let the ocean have her, it's junk.
Nate5.0 is offline
Old 04-26-2016 | 08:17 AM
It is not a problem unless you are leaving it in the water a long time. I have not been able to determine why I see it sometimes and not others. This was after a week in the Gulf of Mexico. Now the good news is that it will wipe right off with CLR, a product available in the grocery store.
Since it comes right off, it appears to be a plating rather than corrosion. This makes sense as the stainless will be cathodic to the rest of the drive. It may be stray current induced (why it appears at some docks and not others). We don't boat in the gulf more than once or twice a year, but have noticed it on occasion.
[ATTACH=CONFIG]554705[/ATTACH]
[ATTACH=CONFIG]554706[/ATTACH]
Attached Thumbnails White Scale On Stainless Parts In Salt Water-img_3258.jpg   White Scale On Stainless Parts In Salt Water-img_3259.jpg
BajaDan is offline
Old 04-26-2016 | 12:28 PM
You can also use Lysol TOILET BOWL cleaner, the gel, straight out of the bottle. Use a sponze, spread it around, open a beer, rinse off with water!!!
CDShack is offline
Old 04-26-2016 | 05:44 PM
Originally Posted by Nate5.0
It's white death
* then buy a C.C.
ICDEDPPL is offline
Old 04-26-2016 | 06:50 PM
Fanboat*
12meter joe is offline
Old 04-27-2016 | 07:17 AM
Originally Posted by ICDEDPPL
* then buy a C.C.
I have moved on to wind power....get your game right buddy.
Nate5.0 is offline
