Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Do any non-bravo drive setups fit a TRS cut-out? >
Old 05-01-2016 | 09:03 AM
Default Do any non-bravo drive setups fit a TRS cut-out?
Old 24 Pantera. Putting together a 450-500 hp 454 for it. It is a rare well preserved beast that doesn't need stringers or a transom. I have 2 Merctrans trannys for it. So it will probably hold up a while, but if something like a 3a thru 6 would fit the TRS cutout, at least with minimal filling, it might be something to spend the winter shopping for. I know. Konrad.
dereknkathy is offline
Old 05-01-2016 | 09:20 AM
Rookie's Avatar
Curious what the issue is? If you are worried about the tranny replace it with a BW and move the engine forward a bit. The TRS I believe would be the least of your worries. The torque on the 454 isn't going to be that much. On my 600HP 454's the peak torque was only 564@5200RPM.
Rookie is offline
Old 05-01-2016 | 01:23 PM
So you want to leave a merc trans but go with a different drive?
Unlimited jd is offline
Old 05-01-2016 | 08:32 PM
no. just running it for the time being. paid for and all...just wondering if anything else fits without major transom mod. BTW, thought I posted this in drive section...
