Throttle up for spring and upgrade with Livorsi Platinum Series Controls
Livorsi Marine’s Platinum Series is designed to be more ergonomically comfortable to the operator while being lighter and more compact for fitting into tight spaces. The Platinum Series is finished with a two coat process which prevents corrosion. Controls can be configured for single or multiple engines for Drives, Transmissions, Jet Drives or Buckets. Available in three throttle/shift configurations: Fully Mechanical, Fully Electric or Mechanical/Electric Hybrid.
The Platinum Series has 3 different styles that can be customized in any configuration imaginable. The styles include; The Standard style for the classic look, The Billet style for racing performance look, and the Arched style for the modern "edgy" performance look.
· Compatible with throttle, shift, jet drives or buckets (1 function per handle)
· There are three different styles to choose from- Standard, Billet or Arched
· Billet aluminum construction makes these controls tough yet lightweight
· Corrosion Resistant, two layers of protection-
· anodized base coat
· powder coat finish
· Shorter base depth: mechanical units measure 8.125" deep, while the electric units measure 6.5"
· Ergonomic knobs for long hours of comfortable operation
· Controls feature friction and detent that may be adjusted while installed on your helm
· Flat base and the optional contour base color options include chrome, simulated carbon fiber or a powder coat finish
Configurations include one or any combination of the below:
· The use of mechanical 33C or 43C cables for mechanical levers
· Electric configurations use compact direct driven angular sensors - 0-5 Volt electronic sensors or a PWM signal
· The use of a micro switch or potts for electronic transmission shifting
· Single, twin and triple in-handle trim switch to actuate your drive, tabs, jack plate, etc.
· Check with the engine manufacturer or Livorsi Marine for electric control compatibility
