Can Oil Pressure Gauge be used as Fuel pressure Gauge? >
Old 05-09-2016 | 08:39 AM
Default Can Oil Pressure Gauge be used as Fuel pressure Gauge?
Bought a gauge set for an I/O and will actually be using them on a fuel injected outboard. The set has an oil pressure gauge but no fuel pressure gauge, would the oil pressure sending unit be fuel compatible? Or could I possibly use the fuel pressure sender with the oil pressure gauge. I know it is kinda a goofy question but it is "budget" build and I have spent way too much on it already.
JRider is offline
Old 05-09-2016 | 10:03 AM
If it's a budget deal go for it. worst can happen is u have to change out. Around the shop I've used various gauges for multiple different uses including fuel pressure and by surprise they worked. I would think the senders would be the same and more than likely will get reading on gauges but how accurate not sure. Ck water section u might find some otherwise. Is it fuel injection application?
It would just bug me like no tomorrow but hey.....
getrdunn is offline
Old 05-09-2016 | 02:06 PM
Is it electric or mechanical gauge?
turbo2256b is offline
Old 05-09-2016 | 03:42 PM
Tinkerer's Avatar
Should work just fine. just don't confuse the two gauges.
Tinkerer is offline
Old 05-09-2016 | 08:41 PM
Let me clarify, 2 stroke 2.5 merc racing outboard, so fuel pressure and oil pressure are the same if you really think about it....lol
JRider is offline
