Vehicle Recommendation Please
Old 05-11-2016 | 10:53 AM
Default Vehicle Recommendation Please
Is it possible to get a viable10K lb tow vehicle for under $8K (less is better, this vehicle will only be used for towing ~ 5 times a year)?
10K lb may be an overstatement of need, I will be towing a formula 272 sr-1 which I believe is ~ 6K dry and it will sit on a tri axel trailer having brakes on 2 axels. So all loaded up and playing it safe I am calling it 10K but in actuality it may be less?
Only requirements for this vehicle are cost and safety/reliability (and it must be able to do highway speeds). If possible, what sort of vehicle/vintage should I be looking for?
Thanks!
scottgjerdingen is offline
Old 05-11-2016 | 01:13 PM
Perfect candidate for you. The 8.1's are great, just thirsty.
http://www.offshoreonly.com/classifi...00-o65285.html
Griff is offline
Old 05-11-2016 | 01:48 PM
WOW, that's a beast!
Old 05-11-2016 | 02:53 PM
Agreed, any GM with the 8.1 and 4.10 rear end. Suburban, Yukon XL, Sierra 2500, Silverado 2500, Avalanche 2500.
techman is offline
Old 05-11-2016 | 03:27 PM
I have been looking for something like that.... who's is it? (member name)
phragle is offline
Old 05-11-2016 | 03:33 PM
SB
Look at the 1st pic where you can see behind the passenger frt wheel. These GM's rot big time underneath. Trust me. 04's and 05's are even a mess here. Not many GM trucks older than this around anymore. I would assume IL close to the same.
Always get a qualified 2nd look at any GM truck...up on a lift....and go nuts.
Fuel lines, brake lines, fuel tank senders (only available as a pump/sender, etc module) and then of course rocker panels and frames and etc.
I've gotten many at work that where just bought (used) and either need $2k+ worth of work, or have to go to the junk yard. Unfortunately in my state, you can sell a car 'As is" without any lemon law protection. Suks being the bearer of bad news.
SB is offline
Old 05-11-2016 | 08:37 PM
What he said. I love my 03 2500hd 8.1.
turbo rr is offline
Old 05-11-2016 | 11:05 PM
I'm in somewhat in the same situation.
I currently have a 1999 Dodge 1500 4WD that pulls our boat but it doesn't PULL as well as I would like- it has about 123000 miles. I have been looking at a replacement - the desire of my heart would be at least a 3/4 ton diesel, 4WD extended cab and short bed. The problem is that we don't use this truck much at all and I cannot justify spending a lot of money on a vehicle that sits in our garage- I think when I purchased the truck in 2009 it had 90K on it so you can see in the 7 years I put on around 20K miles. I have looked at CarMax and local used car/truck lots and some of the junk and prices that they want are simply crazy- I don't want to spend more than 18K. I live in northern Indiana and if anyone has a solid lead please pass it my way.
Take care and safe boating
3pointstar
3pointstar is offline
Old 05-12-2016 | 01:11 AM
No idea. I just remembered seeing it in the classifieds and posted the link.
Griff is offline
Old 05-12-2016 | 07:28 AM
Griff nailed it before i could, I have a 2001 Chevy Suburban 4wd with the 8.1 and its a beast at towing! Mines been beefed up a bit now but even when it was stock it would pull anything at all. I have a 31' Scarab and when it's loaded with fuel and the truck is filled with people and coolers it still just chugs up and down the Ozark Hills all day long without a hiccup.
gmgearhead454 is offline
