1990 28 Apache brave
Old 05-12-2016 | 07:05 AM
Default 1990 28 Apache brave
Hey everyone,New to the site getting ready to by my first big boy boat.Had a few river boats in the past,couple jets and a 22' checker with o/b.My buddy has a 90 28' brave in nice shape been kept under a car port and covered for most of its life.I have been in the boat a few times and seems solid.Has fresh twin 540's with bravo's.has a few issues,needs a new hatch on the deck,said it blew off one day but he made a temp to keep it covered,a few electrical gremlins with the drives and tabs,think maybe just ground issues.Biggest problem is the fuel tank is oxidzing on the inside from the great fuel we have and fuel filters start to clog in about and hr or so of running the pressure drops from 7psi to around 3 to 4,so u have to kinda limp her in.Is it a major tear down to replace the tank?I have the capability to do the job but don't want to have to cut the boat up to replace it,Thanks for any info.
mod58 is offline
Old 05-12-2016 | 07:18 AM
I'm guessing the tank is a belly tank, which means cutting up the floor, removing the tank (likely in foam), spending $1000 on a tank, $100 on 2 part foam, $100-300 on cloth and resin, and a bunch of time. I just did one, and it's not a couple hour job.
Speedracer29 is offline
Old 05-12-2016 | 09:06 AM
Yea i'd say not a couple hour job for sure!!Great pic's and info Thanks!!Doesn't look to bad of a job though,I think I will try and beat him up alittle more lol! Is that a factory replacment tank?Great job!
mod58 is offline
Old 05-12-2016 | 09:27 AM
Tank is from RDS Aluminum in Florida, they made the original tank and still had the blueprints, I just gave them a tank model number, capacity, and credit card number. Three weeks later a semi with a new tank magically appeared!
You may be able to get down by the sending unit and read the label on that Apache, I'm not certain who they sourced their fuel tanks from. I'd highly suggest asking on the Apache forum where, specifically, the tank is located. I'm guessing it's between the cabin bulkhead and engine bay bulkhead, but that's pure speculation. Measure everything a half dozen times before you start cutting the floor! If it's foamed in, a bread knife and an electric chainsaw will be your best friends. Then you'll have to get a steel cable or a poly strap under the end of the tank, hook it to a 4x4 post, set that on some bottle jacks placed on plywood, and start pumping the jacks to break the bond on the bottom foam.
Old 05-12-2016 | 10:42 AM
Funny how that little piece of plastic works!!Yes,the tank is under the cockpit floor.Goin sunday to climb all over and under it and maybe bring it home!Thanks again for all the info!!! very much appreciated.
mod58 is offline
Old 05-12-2016 | 11:20 AM
Gordo's Avatar
Charter Member #94
What graphics are on the boat? Where was it located?
Abby-someone
Gordo is offline
Old 05-12-2016 | 12:21 PM
Down in jersey,haven't seen it uncovered in two years,think it just has the Indian heads on the sides and deck.
mod58 is offline
Old 05-14-2016 | 04:44 AM
Nykamp's Avatar
If you pass on it private message me his information, I am looking for a 28.
Nykamp is offline
Old 05-14-2016 | 05:30 AM
jeff32's Avatar
Make sure you dont run the boat with only 3 pounds od fuel pressure, you might get melted piston running like that, giving you much more problem and $ to spend on top and above your fuel tank job!!!
jeff32 is offline
Old 05-14-2016 | 08:52 PM
No prob,goin tomarrow to help uncover and put new battery's in it.will post some pic's.
mod58 is offline
