some 4150/4500 dyno info
548 ci
Vic Jr 4150 intake
AFR 305 heads
2 inch open spacer / adapter on all pulls
1st pull Pro Systems 4150
2nd pull Pro Systems 4150
3rd pull antique Holley 4500 pre Dominator (nascar)
4th overlay pull 2/3
Vic Jr 4150 intake
AFR 305 heads
Straight bottoms and flat decks
Round 2 different intake and more modern carb. Posted one at a time seems a little clearer
Vic Jr 4500 Dominator flange
Pull 1 4500 Quick Fuel ( no more antique Holley)
No spacer
No spacer
1 inch HVH SS, 34 degrees vs 36 degree timing overlay. 34 is the one that made more power
Notice the first post with all the pulls grouped together was with a 4150 flange Vic Jr with two different carbs. The individual posts were done with the 4500 flange. I guess I could've posted it better, sorry. Hopefully it helps someone.
Specs on the 4150 carb. I'm sure jets and possibly bleeds are not what is on the sheet. Just posted it for the basics.
