Rebuilt 7.4 Mercruiser long block with new dual plane intake
Fresh machined, new cast pistons, main/rod bearings, oil pump, complete valve job with new springs retainers locks and cut for teflon seals, Comp cams Extreme marine XM 262H-12 hydraulic flat tappet camshaft, oval port heads,new dual plane intake manifold, fresh never fired. Long block with no tins including the intake manifold $2,500.00. I can provide this engine complete ready to drop in if desired for additional cost. This camshaft will work with stock cast iron exhaust. Pictures taken during the assembly are available upon request.
