Will My Boat Plane With 3 Blade Mirage+? >
Old 05-18-2016 | 11:44 AM
Default Will My Boat Plane With 3 Blade Mirage+?
22 Donzi Classic, 525 EFI, XR/Imco -2" shorty. Prop shaft about 5.5" below bottom. I really want to try a Mirage+ prop to see how it affects top end and overall handling. I'm now running a 30p labbed Bravo 1 which works very well but is it holding my top end down? I run 83 mph any day, 86 best & bumping limiter @ 5,400 rpm.
My concern is that my boat will not plane out with a 3 blade prop. I don't have access to a prop to try for free so it will be costly to try one through BBlades especially if it doesn't work and I don't buy it. What is the consensus here. Will my boat plane out ok? Will I see a significant improvement in top speed? Thanks.
thirdchildhood is offline
Old 05-18-2016 | 01:08 PM
My guess is NO it probably won't get on plane and even if it did, the prop would have significant blowout.
Griff is offline
Old 05-18-2016 | 01:34 PM
Dave M's Avatar
Veteran: Navy
What Griff said. The 24 Superboat I had couldn't keep a Mirage+ hooked up and it chine walked all over the place. Bravo prop handled great and yielded the same speeds..
Dave M is offline
Old 05-18-2016 | 01:52 PM
Great info. Thanks.
Old 05-18-2016 | 02:06 PM
If I remember right Mik had a 525, its been a while but I think you are pretty close to whaat he was speed wise.... I remember being in it at just under 80.
phragle is offline
Old 05-18-2016 | 02:32 PM
"Hot Shot" Mick Ong? That was a 525 Raylar kit on a 496. He was just under 80 and has since sold the boat. My shorty was intended for his boat.
Old 05-18-2016 | 02:40 PM
Yeah, his red white and blue one.... it was a few years ago so the memory is a little vague. But that was the ride that helped make the decision for me to make the Avanti a sit down.
phragle is offline
Old 05-18-2016 | 03:43 PM
I wouldn't mess with what you have. Sounds like its set up pretty much as best as it can
boats74 is offline
