New hydraulic steering install hooking up rams >
Old 05-21-2016 | 08:43 PM
Default New hydraulic steering install hooking up rams
Installing a new IMCO full hydraulic system, so far pretty easy install. Got the wing plates mounted and the triangle ram plate. Rams were shipped fully collapsed, any tricks on how to get them pulled out. Tried with none of the lines hooked up just couldn' t get the it to move at all. I was just thinking on waiting until the rest of it was hooked up and getting a little pressure on them. As they sit now I can't get them hooked up to the wingplates. I also tried putting a pipe in the eyelet and pulling pretty good on the rams...... nothing.
Questofpower is offline
Old 05-21-2016 | 08:46 PM
If no lines or plugs and they won't move, I'd think the seals are just tight since new. My tabs were the same and finally popped with some pressure.
TxHawk is offline
Old 05-21-2016 | 09:01 PM
That's what I am thinking too. Even tried turning them a few times in both directions thinking they might be in a shipping lock...no dice.
Old 05-21-2016 | 09:03 PM
If no lines are hooked up, eat more wheaties,,,,,
phragle is offline
Old 05-21-2016 | 09:39 PM
That's might be the problem, I am more of a lucky charms guy. I will eat some wheaties in the morning and report back..��
Old 05-21-2016 | 11:08 PM
Try a little air on one side as you tug if possible.
buck35 is offline
Old 05-22-2016 | 07:58 AM
TomFTM's Avatar
You might have got a set that had tight seals, there was some Rams that Imco used a different set of seals and made the Rams extremely tight and hard to move. We had this problem on a new set and we sent them back and they resealed them and they were much better.
TomFTM is offline
Old 05-22-2016 | 08:24 AM
c_deezy's Avatar
Like said above, shoot a little compressed air into them with a rubber tipped blow gun to get them extended.
c_deezy is offline
Old 05-22-2016 | 03:37 PM
OK I did eat wheaties....that didn't help
Compressed air....that didn't help
Tried just putting pressure to the extend side, nothing I am at a loss.
Old 05-22-2016 | 05:04 PM
TomFTM's Avatar
Read my other post , then call Imco ...
TomFTM is offline
