Convert 496 H.O. Mercruiser to MAG >
Old 05-23-2016 | 06:23 PM
Question Convert 496 H.O. Mercruiser to MAG
Looking to convert a Mercruiser HO to a MAG. Had to buy a HO because a Mag was not available at the time. The HO power band is bad for my application. I have a 496 mag in my garage that I can pull the cam and pcm from. Is this all it would take to revert back?
lderekj is offline
Old 05-24-2016 | 04:26 PM
Swap the throttle body too if swapping cam and pcm. I believe some HO applications had a larger air hole in throttle plate. IMO, stick with HO setup. Torque curves between mag and ho are very similar.
Ryan00TJ is offline
Old 06-06-2016 | 08:57 PM
are you looking to sell the pcm or other parts form the ho?
formulajohn272 is offline
