Bravo out drive shift bellows replacement >
Old 05-29-2016 | 10:22 PM
Default Bravo out drive shift bellows replacement
What is the easiest way to replac shift bcable bellows
blaquebaja is offline
Old 05-30-2016 | 12:20 PM
BUP
the only way for the easy R &R is, do have the correct OEM service manual to follow that and all the OEM procedures. And it even has some pics to follow along.
BUP is offline
Old 05-30-2016 | 04:27 PM
Don't know the easiest way but I was going to change mine as a precaution while I had everything apart changing out my U-joint bellows. Then decide against it when it looked like I had to pull the shift cable completely out from the handle.
vindicator101 is offline
Old 05-30-2016 | 09:44 PM
Thanks for the reply. Changed it today took less than one hour. I raised the out drive all the way up turned it the left cut the old bellow out removed the hose clamp with 5/16 with universal disconnect shift cable from shift bracket removed the end of the shift lever pull cable through housing slide new bellow on slide back into housing connect shift bracket tighten s/s hose clamp. Done and went to down town Jacksonville for four hours!
