Solar dock lights?
Old 05-30-2016 | 09:08 AM
Default Solar dock lights?
Got a *****in dock at my new place and would like to light it up a bit. A quick google search shows a couple million options, I like the almost flush mount ones that I'd be much less likely to crack my foot on. Looks like you would put them every 6 ft or so. Anyone have any real experience with them. Fresh water lake application.
X-rated is offline
Old 05-31-2016 | 09:23 AM
Hi X-Rated-- I won't even go to the origins of your screen name!!! LOL
If you go to Amazon there are a number of dock led light that are out there. The every 6' approach has got a couple that require a hole to be drilled in the dock and they are surface/flush mounted. We have a Roll-O-Dock and I don't want to drill any holes in the aluminum - what we have done is bought these "cheap" yard lights and put them into the support poles - they really work well and when the fail - which they all do - it is an easy and inexpensive fix.
A couple of weeks ago I was up north of Kalamazoo Michigan and there is a dock/pier boat shop right on US 131 that had some great looking pole mounted dock lights -- Being the idiot I am- I don't their name. If I get a chance to run up there again - I'll pass it out to this posting.
All the best
3pointstar
All the best
3pointstar is offline
Old 06-15-2016 | 01:22 AM
Costo.com
5"x5"x.3/4" tall all aluminum
and cheap
boating4me is offline
Old 06-15-2016 | 09:30 AM
NWfreerider's Avatar
I got mine from Costco but they are plastic. They work great.
NWfreerider is online now
Old 06-15-2016 | 09:54 AM
Are you trying to light up the dock where you walk or the boat slip?
I have used ones like these for years to help locate the ends of the dock and slip...mounted them to the side of the dock, nothing to step on.
http://www.lowes.com/pd/Portfolio-2X...ht-Kit/3831797
I hate too much light when docking at night.
Also learned it's best to open them up and coat the electronics in clear silicone. Makes them last a lot longer.
BradH is offline
