Length on Trailer: 29 OL, 30 OL, 302 >
Old 05-31-2016 | 07:42 AM
Default Length on Trailer: 29 OL, 30 OL, 302
Well I'm ready to upgrade. Will be looking at 29 outlaws, 30 outlaws and 302s. Preference is a newer 30 OL, maybe 2006/7 vintage.
Need one of those three to fit in the new garage which is 37' long inside. Any help with measurements from tip of tongue to tip of prop (drives up) on the trailer would be great!
Thanks everyone!
jetskidrewski is offline
Old 05-31-2016 | 07:49 AM
Sydwayz's Avatar
Forum Regulator
From another thread in this section:
Originally Posted by Sydwayz
Boat plus 7 feet is a good solid & conservative number to go by.
Aluminum bolt-together trailers are typically longer than welded steel or welded aluminum trailers.
Surge brakes adds about 1' foot to overall length due to the coupler.
ITS drives or stand off boxes will add to that, as much as 12 inches.
You should be OK. If not, you may be able to cheat a little by sliding up on the trailer, or perhaps upgrading to EoH brakes and shortening the tongue a bit.
A neighbor had a special trailer built so he could fit is 30 Outlaw in his garage, which was 34-ish feet I believe. It had a really short tongue to where the bow was pretty much over the trailer jack/foot.
Sydwayz is offline
Old 05-31-2016 | 08:00 AM
American custom marine has a super clean 2008 30 outlaw for sale
soundwave is offline
Old 05-31-2016 | 08:22 AM
Steel Outlawed's Avatar
This may help a little my 33 Outlaw on a Manning Marine aluminum trailer is 42'-6". The trailer does have a drive guard which is basically about 8" past the drives when they are in the up position. It will depend on trailer manufacturer also because some trailers have longer tongues than others. Hope this helps you some.
Steel Outlawed is offline
Old 05-31-2016 | 11:19 AM
Thanks Sydwayz - I remember that from another thread, but I'd like to get a couple real numbers from owners since I don't know of any local 30 OLs or 302s.
soundwave - I'm considering going to look at that one, I like the colors, but there are a couple things on that boat I don't like as well...
Old 05-31-2016 | 12:57 PM
30 ol
Originally Posted by 92nsx
35' 10" . Call it 36' . Heritage trailer.
With 37' deep garage you won't have much wiggle room.
92nsx is offline
Old 05-31-2016 | 05:20 PM
My 30 OL on a Loadrite trailer is 37' tongue to props with the drives down.
bajario52 is offline
Old 06-02-2016 | 06:40 AM
Thanks bajario52 and 92nsx, these are the numbers I'm looking for.
Any 302 numbers from anyone?
If a 30 OL or 302 won't fit in the garage then I'm going to get a 335 and just keep it on a hoist or rack.
Old 06-02-2016 | 08:35 AM
Sydwayz's Avatar
Forum Regulator
There are a couple lengths in this thread:
http://www.offshoreonly.com/forums/b...-ol-302-a.html
There are also a few cheats you can do. Installing EoH brakes can save you a foot sometimes, plus it makes for a better tow.
Others have put a little "doghouse" on the back of their garage to allow the drives/swim platform to extend into.
This is a friend's solution at his summer place:
Sydwayz is offline
Old 06-19-2016 | 09:36 AM
Potential new problem... Height, what are height measurements from the ground on these three boats?
My garage doors are 8' tall.
