looking for steering fitting, does it exist? >
Old 06-03-2016 | 09:18 AM
Default looking for steering fitting, does it exist?
The strange fitting with the little o-ring where the high pressure hose connects to the late model merc internal steering ram. Id there an adapter fitting to use this hose and screw it into a latham steering filter? (looks to be a standard an fitting comming out of the filter)
phragle is offline
Old 06-03-2016 | 09:57 AM
post a pic, a hydraulics shop was able to get a new fitting that went to my steering filter. Was machined wrong and lived with it leaking for years.
JRider is offline
Old 06-03-2016 | 10:29 AM
This piece shown in the photos is from a Mercury Verado pump hose. Is this it?
[ATTACH=CONFIG]556083[/ATTACH]
Taboma is offline
Old 06-03-2016 | 10:43 AM
yep pretty much like that!
phragle is offline
Old 06-03-2016 | 11:32 AM
Run down to Parker, they may have that in stock for you.
Baldie is offline
Old 06-03-2016 | 11:46 AM
SB
Tell them to look under Saginaw Power Steering fittings...there's various sizes like 16mm x 1.5 and 18mm x 1.5
Obviously, have them check yours for thread size and type.
GM uses these for some of their EFI systems too.
Many places sell these fittings, so your hyd shop should too:
SB is online now
Old 06-03-2016 | 02:34 PM
Wobble's Avatar
SORE MEMBER
I was going to say saginaw also
Wobble is offline
Old 06-03-2016 | 03:14 PM
Imco has a fitting that's 3/8 male npt, to female for the line to thread into
Unlimited jd is offline
Old 06-03-2016 | 04:31 PM
got that comming from imco. As for Parker... they are off my list. they charged me over $100 to make 2 14" 3/8 hoses, and refused to put their fitting on the brand new 3/8 hose I had, Went to Agri-Supply today and they made 3 hoses for me using my hose and their fittings. 1 from the filter to the helm and the port and stbd hoses from the helm to the ram thruhull fittings. $45 for everything..
phragle is offline
Old 06-04-2016 | 07:29 AM
https://www.holley.com/brands/earls/...tion_adapters/
Jeff
hallj is offline
