Drives,Stainless Marine tails,crossovers,valve covers,pulleyss, fuel pumps,etc >
Old 06-05-2016 | 05:52 PM
Default Drives,Stainless Marine tails,crossovers,valve covers,pulleyss, fuel pumps,etc
All parts are off central texas fresh water boats I have owned ..
Best way to get ahold of me is email,not posts and not PM, if you post here and someone else emails me they will have priority as I dont spend my entire day checking this place out or checking my PMs however I do check my email at least once every hour. [email protected]
PRICES DO NOT INCLUDE SHIPPING..
I prefer that you pay me for part,,I box it up for you for free and I drop it off
at UPS here in Lago Vista and you pay them directly for shipping..
This ensures
1.That you pay exactly what shipping is and I dont make any money off it.
2.If there is an insurance claim you get paid since you paid for the shipping
Phone for ups in Lago (512) 267-2924
Two Alpha Ones with props,,have drive showers but missing the
hoses to hook up,,the steering saddles do not come with them..
They were working when remmoved from a boat I parted out.
Outside of that do not know condition. $500 takes both drives and props..
Two pairs of TriStar BBC valve covers will clear girdles basically new,
$75 a pair
Two CPPerfromance Big Block Cast Stainless Steel Crossover Kit 520-454K Water inlet can be plumbed from the port to starboard by rotating the inlet for custom rigging applications. Crossover is a 1-piece stainless casting and highly polished. Sell for $339 each new I wll take $150 each.. In very nice shape.
Two seawater pump / fuel pump setups,, fuel pumps are like new , the rear housing is not there,, I would highly reccomend using the stainless steel replacement CP sells,,the plastic Merc ones are crap. The Pulleys have been painted with Merc racing blue paint which alone adds 50hp to your engine.. I also have the brackets to mount them. I want $400 for both setups with brackets. Will sell seperate if no one buys both after a week or so.
Two sets of older Mercury racing valve covers that have been stripped,painted gray.
$75 a pair
CP Performance fuel pump module to be used on the Mercury seawater pump setup,
it is fitted with AN10 inlets and outlets,,flows better than stock Merc but not as well as the CV perfomance one. I had it on my supercharged engine,, was good to around 600hp,once I pullied up I started seeing some pressure loss and went to the CV pump. anything under 600hp this will work wonderfully..
Stainless marine tails ,, these go thru your transom, came off Bravo boat,,these
are dry to the tip. Great for big cam / high hp setups. In very nice shape.. They are 4" diameter.
$500 for all 4..
Stainless Thermostat kit for supercharged BBC, Designed for 8-71/14-71 Kit with Bypass. . 3/8" NPT sender port. $150 new at CP,, sell for $50 new in bag
Two Mercruiser distibutors , from HP500s , $100 each
Set of Mercruiser Racing mounts for side by side TRS boats..
FREE,, Ill drop at UPS and you deal with them for shipping.
PICTURES are in the following album,,its a public album but you may have to be signed into Facebook to see it.
https://www.facebook.com/media/set/?...7757563&type=3
HTRDLNCN is offline
Old 06-06-2016 | 02:44 PM
all pulleys have been sold
HTRDLNCN is offline
Old 06-06-2016 | 09:46 PM
also selling a set of 1.7 Scorpion roller rockers,, in great shape.
$200
https://www.facebook.com/Frank.No.Pr...7757563&type=3
HTRDLNCN is offline
Old 06-06-2016 | 11:14 PM
rockers are sold
HTRDLNCN is offline
Old 06-08-2016 | 11:23 AM
Merc valve covers sold.
HTRDLNCN is offline
Old 06-10-2016 | 12:13 PM
alpha drives and tailpipes have sold
HTRDLNCN is offline
Old 06-10-2016 | 11:37 PM
Holley carbs for sale.
Carbs have been sitting in my garage for years so all need a good cleaning
and new gaskets..
Carb 1 : 80311 850cfm vacuum secondary Marine Jets 80/89 $100
Carb 2 : 4781-2 850 douple pump Marine Jets 84/84 Missing sight pugs and one float $125
Carb 3 : 4777-3 650 Double pumper Automotive Jets 70/73 $75
Carb 4 : 9022 800cfn Double pumper Marine Jets 74/87 $125
HTRDLNCN is offline
Old 06-12-2016 | 11:06 PM
selling four Big Block manifolds,, two are Mercruiser cast ,, one s aftermrket cast,,nd on is GLM alumium ,,all are in excellent shape,,$50 a piece.manifolds only,,risers not included,,. pics in the original album up top..
HTRDLNCN is offline
Old 06-13-2016 | 11:00 AM
Do you have a sea water pump bracket ? One for the seapump with the fuel pump on it ?
Matjluk is offline
Old 06-15-2016 | 11:06 AM
Matt ,, replied to your email if your the same Matt.. :-)
HTRDLNCN is offline
