Just installed a SCX upper and Scx -2 shorty imco old style blunt nose? >
Old 06-06-2016 | 09:38 AM
Default Just installed a SCX upper and Scx -2 shorty imco old style blunt nose?
So I just recently installed a new scx upper and scx -2 lower blunt nose style on my '29 VR-1 from having a XR upper and standard sportmaster lower, and I seem to lost 10mph if not more, the boat handles horrible and the prop slip is threw the roof, can anyone help me out on what they think I need to do to get back where i was? You think standard SC with the SCX upper is the way to go? I'am currently running a P5 32 done by b-blades, I ran it up to 88gps at 6000rpms and got nervous so backed out , slip was like 26.5% , I should mention I'm running a 8inch stellings box as well, I was running a tad over 100mph with my old set-up , any help would be greatly appreciated, I just got sick of replacing the XR's .
1sickvelocity is offline
Old 06-06-2016 | 09:48 AM
Revelocity's Avatar
I would definitely work back toward your previous x-dimension using drive spacers. Single engine Velocities have very mixed results with shorty drives and -2" clearly seems too short given your results. Good luck.
Revelocity is offline
Old 06-06-2016 | 11:35 AM
ziemer's Avatar
I agree. Sounds like you need to go back to the original height. Can you try a couple different spacers? Maybe drop it down 2" and work back up 1/2" at a time.
ziemer is offline
Old 06-06-2016 | 11:46 AM
The scx lower is a lot of the problem. Swap the lower and you should see some speed return. The scx upper and lower uses a lot more power than standard xr. Seen it tried on a SVL and a big Fountain same result lost 8 mph.
Aqua Banshee is offline
Old 06-06-2016 | 12:51 PM
Thanks guys, Im gonna order a SC standard Imco, and see where my cars fall. Stay tuned
Old 06-20-2016 | 08:45 AM
Quick update date, we did the Sacandaga Fun Run this past weekend, I had a chance to put my sportmaster standard lower back on with my IMCO SCX upper , and Im back in business again, I learned that my VR1 absolutely hates the -2 shorty along with the blunt nose scx lower, so I think the end result, is I will be just putting gears in my lower sportmaster every 70-90hrs rather than sacrifice 12 mph lol, I spent to much money to get where Im at to lose that much speed, 2-3 mph I could deal with , but not 12, we ran 101mph in the run Saturday with a full tank of gas, so that is where Im as of now, just in case anyone was wondering my X dimension is 3.5 below and that seems to be the sweet spot for my boat My X was only half inch below with the shorty, anyone else wanna share there sweet spots?? Please feel free...
Old 06-20-2016 | 02:55 PM
Nice update!
Curious what you are running for power to run that mph.
underpsi68 is offline
Old 06-20-2016 | 02:59 PM
Nice to see you got that 2" back, now can you see over the dash? Sorry Mike had to say it, your boat looked good
Rockyone is offline
Old 06-21-2016 | 09:48 AM
I have a booster seat Rock haha
Old 06-21-2016 | 09:50 AM
Im running a Saris built 825hp , basically a 525 with a whipple, little different cam and a little lower compression, as whipple instructed.
