Lifter question
Old 06-06-2016 | 10:46 AM
Lifter question
HELP Maybe there is someone that can give me some GOOD advice. I have GM 502's and have a nocking sound in one of my valve covers at higher RPM's. Up to 3400 everything is great above that I start to get noise. I suspect I have a lifter not recharging. I am planning on replacing them but do I need to replace the cam at the same time. I have been told all different things , Thank you
chuckm is offline
Old 06-06-2016 | 10:49 AM
SB
By your description Chances are it's something else, like a valve spring issue or rocker arm.
So, here's the best advice, pull the VC now and start inspecting. Then go further (lifter) if needed.
SB is offline
Old 06-06-2016 | 10:53 AM
F-2 Speedy's Avatar
no..............you need to first find the problem, usually valve train noise is more of a ticking, bottom ends knock
F-2 Speedy is offline
Old 06-06-2016 | 11:48 AM
PigNaPoke's Avatar
Rod bearing FTW...
PigNaPoke is offline
