353 Cabin sink drain into Bilge
Ok so Im not too pleased with the cabin sink drain dumping into the bilge. I dont need pop, beer, or gatorades going in there.
Anyone pop a hole through the side? Do I need to watch out for any hull liner or other structural shlt?
On our 05 353 the drain for sink went into the bilge, that's just not cool when a relative pours red Kool Aid into the sink and ends up in your white bilge. I looked into modifying it and was going to install a "shower box" and dump out the stern under the platform like the rest of the factory hook ups. I remember there being some sort of issue with height of the sink relative to the water line also. I called Formula parts dept and talked to them and they said the factory did not want any un-sightly holes in the sides of the boat so that is the reason for all the discharge points under the swim platform, for what its worth.
I think your best option is going to be as Voodoo recommended. Install a shower box with a float switch and tie it in to an existing or drill a new thru hull. At least this one will be above the water line.
This is the main reason why I still have a water tank full of antifreeze from 5 years ago and why I don't invite people out on my boat.
I have read you are not suppose to put holes in sides of the hull on the fastech's. However, I have a 353 with factory air that has a water discharge hole about 12"-18" above the water line on the forward starboard side about two feet forward towards the bow were the u-shape sitting area and the v-berth meet. The funny part is the drain pan for the AC has a normal bilge pump that discharges to a diaphragm pump out the aft or below the swim platform. Just a weird set-up.
The sink draining to bilge upsets me too, I was just going to put it in series with my diaphragm pump with a check valve. Just haven't got to it yet.
