Towing an Outer limits SV52 with F250... >
Old 06-06-2016 | 05:21 PM
Default Towing an Outer limits SV52 with F250...
2016 F250 4x4 w/ 6.7 Power stroke on the tow ball....good to go? Single Rear Axle
Dry weight of vessel is 10,800 lbs I believe, not sure about trailer weight.
Renegade1 is offline
Old 06-06-2016 | 05:29 PM
Kelly O's Avatar
You've got the right screen name to make it happen.
Kelly O is offline
Old 06-06-2016 | 05:42 PM
Make sure you get a good class V ball mount that can handle the weight. With trailer and any fuel/gear and you're probably easily over 15k pounds. Airbags in the rear wouldn't hurt either.
ToMorrow44 is offline
Old 06-06-2016 | 05:43 PM
Screams Jimbo Darr......but I will play along:
Sure since the OL is a SV52 and that is like a 250 but backwards then that means it will be fine! The good part is you will be towing the boat twice because at 10,800 that means the boat has been cut in half like those whacky 1960's Boston Whaler commercials.
Please video your trip, surely it will go viral!
Jupiter Sunsation is offline
Old 06-06-2016 | 06:02 PM
Why do I have a hard time comprehending why someone with a 52 ol cant afford enough truck to pull it from one end of the walmart parking lot to the other??
phragle is offline
Old 06-06-2016 | 06:24 PM
That boat might weigh 10800 if it were sitting on Pluto.
UD
Uncle Dave is offline
Old 06-06-2016 | 06:39 PM
UD
SL 52
Length:51'3"
Beam 9'2"
Weight 12,000 lbs
Straight off their website, and that's probably before they put anything in it
So now there are at least 3 threads you have going J.D.
phragle is offline
Old 06-06-2016 | 06:44 PM
OL40SVX's Avatar
Originally Posted by phragle
SL 52
Length:51'3"
Beam 9'2"
Weight 12,000 lbs
That is an SL52 full cabin, loaded, dry weight not SV52. It all depends on which boat for the weight as they had different lay ups and options. Call me at the shop for a weight.
OL40SVX is offline
Old 06-06-2016 | 06:48 PM
UD
Maybe lots and lots of carbon fiber lol...?
Old 06-06-2016 | 07:23 PM
Darr would use an ecoboost f150.
wfo1 is offline
