98 mercruiser 5.7 no spark >
Old 06-08-2016 | 05:16 AM
Default 98 mercruiser 5.7 no spark
Just put in a used 5.7 in a boat i bought over winter.i know its something stupid.no spark.i have a purple wire coming out of harness to + of coil 2 grays to - of coil wh/red wh/green to distrib. Im stumped
Junkgod70 is offline
Old 06-08-2016 | 05:35 AM
SB
Carburetor with Tbolt V distributor or EFI ?
SB is offline
Old 06-08-2016 | 06:17 AM
Are both the distributor and thunderbolt modules grounded? (they both have black ground wires)
Mr Maine is offline
Old 06-08-2016 | 06:23 AM
Its carburated.i see 1 ground off of the bracket on back of distributor that holds the module? To big plugs that come out
Old 06-08-2016 | 06:25 AM
Also i have constant 12 volt on both sides of coil
Old 06-08-2016 | 06:36 AM
It is the mag distributor with the module and knock sensor mount right on distributor
Old 06-08-2016 | 06:42 AM
SB
http://www.boatfix.com/merc/Servmanl/16/16B4R2.PDF
Tbolt V starts on page 16.
SB is offline
Old 06-08-2016 | 06:48 AM
SB
Page 8 here show's complete wiring:
http://www.boatfix.com/merc/Techbk/96/96HGD4.PDF
Since it's pdf, you can increase size of page.Put curser to lower right of screen and you'll see - and + controls to increase/decrease view size.
SB is offline
Old 06-08-2016 | 06:56 AM
SB
That's not good. The gray's that go to - side of coil should not have 12 volts. One gray goes to tach (thru wiring harness) as signal and one goes to ign module so it see's rpm.
Remove gray that goes to tach and re check.
SB is offline
Old 06-08-2016 | 12:14 PM
Ill try that today thanks
