33 avs question >
33 avs question
33 avs question
Old 06-14-2016 | 09:47 PM
Default 33 avs question
Hi,
Hoping someone knows the answer to this question.... in the cabin of the 33 avs is there an access hole to the front bilge underneath the carpet anywhere? I am aware that if there is the carpet has to be pulled up to get to it.
Is the front bilge area connected to the rear bilge?
blutegra1992 is offline
Old 06-15-2016 | 01:48 PM
scarabman's Avatar
What are you looking to do.? There is access. but not down low in the center. You can get to some stuff through the bottom of the storage lockers on either side.
scarabman is offline
Old 06-15-2016 | 03:16 PM
What storage lockers are you talking about? I need to get access to the center front bilge under the floor of the cabin.
Old 07-06-2016 | 01:35 PM
ferraristyle's Avatar
Under the front of the vbirth cushion there is an access/storage panel, but I believe it is enclosed. You may be able to access from the cockpit forward running along the fuel tank and go forward. Other then that don't know.
ferraristyle is offline
