Testing fuel tank >
Testing fuel tank
Testing fuel tank
Old 06-15-2016 | 12:21 PM
Default Testing fuel tank
I have a 1990 Formula 242ss and sometimes I notice some gas fumes in the cabin. Can someone tell me the best way to test the tank in the boat? Pressurize the tank? See if it holds pressure? If so how much pressure? Thanks for any help
riverrunner242 is offline
Old 06-15-2016 | 07:08 PM
weldcrane's Avatar
3 lbs pressure
weldcrane is offline
Old 06-15-2016 | 07:11 PM
14 apache's Avatar
If your going to pressure test it remove the fuel from the tank first.
14 apache is offline
Old 06-15-2016 | 07:14 PM
Is there an option other than pressure I was thinking about smoking the fuel system
Old 06-15-2016 | 07:24 PM
do not pressurize the tank. 3 psi doesn't sound like a lot but multiply the top area of the tank by the 3 psi and see how high the side force is.
kvogt is offline
Old 06-15-2016 | 08:13 PM
Pressurizing the tank won't work. Most are vented to allow for thermal expansion and prevent condensation.
1MOSES1 is offline
Old 06-15-2016 | 08:18 PM
Sonic30ss's Avatar
Hydrostatic- plug vent and outlets, fill the tank until liquid is at the top of fill tube and wait...if it goes down leak
check your vent lines too they could be cracked and allowing fumes to escape
Sonic30ss is offline
Old 06-15-2016 | 08:43 PM
vintage chromoly's Avatar
You can pretty much bet on the tank needing replacement. It's 27 years old and, most likely, unfinished aluminum. Not trying to bust your chops, but that's going to be the case.
I have a 1977 boat and when I had it apart for stringers I decided to go ahead and replace the tank. It was corroded badly on the sides and bottom and ready to start leaking. Glad I pulled it.
700 bucks and three weeks time and I had a new tank at the door. I bought mine from Florida marine tanks.
vintage chromoly is offline
Old 06-15-2016 | 08:47 PM
14 apache's Avatar
Most tanks have a tag on them to let you know how high to test them mine are 5psi in my boat. But all tanks are different.
Old 06-15-2016 | 08:50 PM
14 apache's Avatar
Can you get to your tank easy? Drill some core holes in front and back of the tank and smell the foam. Don't drill through the bottom.
