Was having a good day until... >
Old 06-18-2016 | 03:17 PM
TomZ's Avatar
Default Was having a good day until...
Ignition issues. G*d Damm!t!!
Cruising along at 3K, rpm dropped a touch followed by two rapid pops through the supercharger. The engine stalled immediately, started up but was hard to start and seemed to be missing. Limped it back to the beach, cracked open a beer to celebrate getting out regardless of the issues, and let her sit.
Twenty minutes later she won't start so I mess around with the module plug... starts up fine, seems to be running great, so head back to the dock. Running great still, turning about 3200-3300, exact same rapid fire pop through the blower, and now dead. Getting towed back by my buddy as I write this. Great.
Factory Merc Thunderbolt with V6 module and an older but new MSD 6M2 (6490). It's not the MSD, I bypassed it. Assuming the module died.
What can I replace this with tomorrow morning to be back on the water?! Delco TBI? Will that work?
I'm so f'ing pissed right now. I know I should have replaced this the last go-around.
TomZ is offline
Old 06-18-2016 | 03:39 PM
Throw an HEI mechanical advance in and go. Worse case scenario lock in at 32 deg. Will get you through the weekend anyway. One ignitition and tach wire - time it and go.
getrdunn is offline
Old 06-18-2016 | 04:12 PM
Coil
Black Baja is offline
Old 06-18-2016 | 04:15 PM
TomZ's Avatar
It a new coil.... doesn't mean anything but I don't think it's that.
I don't think a large cap hei will fit with the blower.
TomZ is offline
Old 06-18-2016 | 05:08 PM
If none of the easy stuff fixes the problem, I would do a leak down test. Might be something like a broken valve spring.
BenPerfected is offline
Old 06-18-2016 | 05:39 PM
It never seems that way does it. If it does it certainly isn't with me. Wouldnt it be nice if it was a coil... I can think of maybe one in over 30 plus years one went bad on me.
getrdunn is offline
Old 06-18-2016 | 05:51 PM
Pretty much rules out valvetrain issues from what you described. This seems to be a common thread lately. You checked module etc grounds I assume. Distributor tight and not moving around. Be nice if you had a module you could try. Any luck yet?
getrdunn is offline
Old 06-18-2016 | 05:52 PM
Check fuel tank vent.
PARASAIL941 is offline
Old 06-18-2016 | 07:59 PM
I think you're right on with it being ignition, I've seen more and more modules going bad lately, we've finally found the lifespan of merc tbolt modules
Unlimited jd is offline
Old 06-18-2016 | 08:01 PM
SB
http://forums.iboats.com/attachment....1&d=1300371104
SB is offline
