Titanium Intake valves  $$$$ >
Old 06-20-2016 | 12:50 PM
Default Titanium Intake valves $$$$
So, reading through my paperwork on my motors they have titanium intake valves. Called the machine shop today and told them, then looked up the price! WTF? $165 each!
How much advantage over stainless is the titanium? Would I have to use different valve springs with stainless?
JRider is offline
Old 06-20-2016 | 01:11 PM
SB
Seats probably. But I dunno. I do know Titanium valves is a whole 'nother world than 99%+ of us have been living in.
SB is offline
Old 06-20-2016 | 01:14 PM
I have a titanium valve from a top fuel car, believe it's 2.44 inch, and a monster. I would think with the valve being lighter you wouldn't need as much spring pressure, but I have no specifics.
Mr Maine is offline
Old 06-20-2016 | 01:16 PM
The more I look at these motors the more I think I got a good deal on the boat. They are high dollar.
JRider is offline
Old 06-20-2016 | 03:04 PM
vintage chromoly's Avatar
I swapped my titanium intake valves out for a set of Manley stainless steel.
I was counseled that titanium is best used in class racing where money is no object and the valves get pulled as regular maintenance.
I sold the used Del West titanium valves on eBay for almost 200 bucks (for set of 8) and used the dough to buy the stainless.
vintage chromoly is offline
Old 06-20-2016 | 03:36 PM
I was at a head shop one time and the owner was showing me that the head on a Titanium valve can actually flex. He held the valve by the stem in his fist and with his thumb he could move the head slightly. Freaked me out!
picklenjim is offline
Old 06-20-2016 | 03:46 PM
I ran them in a 69 shelby mustang I HAD WITH A 351c IN it probably built up more than what was allowed in NASCAR. No issues they were around 75 each back then and was cranking over 10K to hit 200+ MPH. I wouldnt recommend them for anthing less than a real competitive class of racing were one might spend 5000.00 just to gain a couple HP. I do recomend Ferrea valves over most.
turbo2256b is offline
Old 06-20-2016 | 04:45 PM
From my understanding, is titanium becomes an advantage, when lightweight and high RPM is the goal. The downside, is they aren't as durable long term, as a good stainless steel valve.
MILD THUNDER is offline
Old 06-20-2016 | 04:51 PM
That is what I was told.
To the op, have you seen video of Bob Teague on the throttles? Spinning a BBC 7500 to 7800 RPM.
Also, if you've ordered much from Teague, you know he has plenty of money to change valves like we change underwear. Brittle, but light.
Old 06-20-2016 | 04:58 PM
14 apache's Avatar
Titanium is a real advantage when you get into large 2.350+ and long valves with high rpm. If you plan on running them in a boat should be Crn coated and they will live a good life. Camshafts I originally had would tare the intake lobes up from the heavy valves. 2.4 intake. Large lifters and 55MM cam core would also help heavy valves.
Crn is used on the valve head to keep the valve face from wearing riding against the seat and you can use regular seats with out problems. They also get a molly coating on the valve stems for low friction.
14 apache is offline
