Staggard driveline long shaft takes more HP >
Old 06-21-2016 | 10:16 AM
B38
Default Staggard driveline long shaft takes more HP
Ever since day one with my Bertram I can not sync motors, always 200 - 300 rpm less with port engine. changed everything over between engines to see if different, No. latest poker run noticed a little vibration on port driveline around 3,600 Rpm, so I pulled driveshaft and freeked out how heavy it was. didn't weigh before I left at driveline specialist but he also stated very heavy for application. Im awaiting for his response. May retube with lighter material. still in a confused state. Starboard shaft is only like 16" long and just a slip joint and two flanges.
My Question to the forum gods. Will it take more Hp to spin the long shaft verses shorty shaft.
B38 is offline
Old 06-21-2016 | 11:14 AM
cougarman's Avatar
http://dynotechengineering.com/
One of the offshore race teams set me up with Dynotech
Pricey,.. but they know there products. bout $800 per engine
Doesn't answer your question,.. but fyi if you ever need another source for parts
cougarman is offline
Old 06-21-2016 | 04:57 PM
I would think not. Even being heavier, longer etc, once it's rotating shouldn't be a difference... Maybe off base here but physics wise, shouldn't cause horsepower loss especially to the tune of 2-300 rpm.
Nuke427 is offline
Old 06-21-2016 | 06:02 PM
B38
Port engine spins apposite of wheel, where as starboard spins same as wheel.that was another thought was tossed at me today. Awaiting drive line guru to call me back with his results. I need it back by Friday. I'm also trying a new set of bigger B4 props . This will be my fifth attempt to find the perfect wheel.
B38 is offline
Old 06-21-2016 | 06:59 PM
Driveshaft angles equal (parallel flanges)? Crosses not in phase (can happen if you have slip joint and put back together wrong)? These things can cause more losses, vibration, even driveplate and gear issues if off significantly.
Falcon is offline
Old 06-21-2016 | 07:13 PM
No.
Flyin-Bryan is offline
Old 06-21-2016 | 08:38 PM
B38
Agreed, Will follow up on what you listed. Thanks falcon
B38 is offline
Old 06-21-2016 | 10:14 PM
Curt- The jack shaft may have been upgraded because of the diesel engines that were in the boat when you bought it. I would see if aluminum shaft is an option.
Wannabe
wannabe is offline
Old 06-22-2016 | 06:34 AM
If the diameter is small the rotating mass is also. A lighter larger diameter lighter shaft can have a greater turning weight than a small diameter steel shaft.
smiklos@sunprint is offline
Old 06-22-2016 | 12:46 PM
Did you try switching props from side to side?
JRider is offline
