Go Back  Offshoreonly.com > Owners Forum > Sunsation
Help finding exhaust wiring 288 >
Old 06-24-2016 | 08:23 PM
Default Help finding exhaust wiring 288
I am adding Corsa Quick and Quiet to my 09 288. The switch on the dash is there and lights but I have been unable to find wire in engine compartment. I have cut loose a bunch zip tied wires that go nowhere. Some are marked, some are not. I checked all with a test light but have not been able to find the correct wire. Any help would be appreciated so I don't have to add wire outside harness.
Thanks Matt
Schwabee1 is offline
Old 06-24-2016 | 09:09 PM
Not sure if this will help but on my Sonic the switch fed a terminal block that was mounted on the transom. Wires from solenoid Went to the block.
sonicss42 is offline
Old 06-27-2016 | 07:43 AM
Found the wire using an electronic wire tracer. It was taped into the main engine harness that goes into back of engine. It was an unmarked, orange with white tracer.
