I need a IAC part number >
Old 06-25-2016 | 05:51 PM
Default I need a IAC part number
I need a part # for a IAC that is used on a 525 EFI with a Whipple. This IAC has an external flame arrester and mounts to a manifold with a hose to the blower. I have those IAC's on my boat but I can't find a part # so that I can replace them. Does anyone have that part number?
jdflchr is offline
Old 06-25-2016 | 08:01 PM
Your Mercruiser engine serial number is always the best way to help find correct parts, But item number 15 in the following link looks to be the Blue Idle Air Valve Assembly you are asking for, http://www.mercruiserparts.com/bam/s...1345/10127/110
lakematdude is offline
Old 06-26-2016 | 08:16 AM
Thank you, my motors a custome built 572's with 4L Whipples so no serial number to use. They have the Mercuiser 555 ECU's so I know the 525 IAC will work. Either way thank you for your help!
jdflchr is offline
Old 06-26-2016 | 10:21 AM
I have a NAPA # at the shop. Call me tomorrow and I can get it for you. 615-216-7449
Eddie
Young Performance is offline
Old 06-26-2016 | 05:59 PM
Eddie
Eddie thanks I would like to get that # from you. Also will you inbox me your email address I have a few more questions I want to ask you about the problems we talked about on the phone. I just I don't want to call while your trying to get some work done. I'll just email you and you can get back to me after business hours when you have more time. I tried to send it on OSO but you inbox is full.
jdflchr is offline
Old 06-27-2016 | 06:40 AM
SB
Would this happen to be it ?
Motorcraft CX1785 Idle Air Control Motor
Motorcraft CG758 Gasket
http://www.rockauto.com/en/parts/mot...ac)+valve,6072
and https://amzn.com/B000C5FHMO
SB is offline
Old 06-27-2016 | 07:19 AM
SB
You may find this 525EFI IAC Muffler / Arrestor thread interesting too:
http://www.offshoreonly.com/forums/d...r-options.html
SB is offline
