Boat pieces parts...
I have a butt-load of parts that someone might be able to use. All are in good to fair condition and all were working as they should when removed. I will be pulling out more stuff later...especially Thunderbolt ignitions. Prices are listed or make an offer fair to me and to you...I might do it. Add the ride to the cost from 76179 zip code. You can probably guess the weight as nothing here is over 20 pounds
2 water circulators that a friend pulled off his boat. They were working fine and he had new motors and also wanted new water circulators...$40.00 each
1 water circulator (I think) from a 4.3 v6...$40.00
1 starter, but I dont think it is a marine and I dont remember how I ended up with it...regardless...$25.00
1 complete ignition set with the ECM and the interrupter switch and mounting plate for a 4.3...$100.00
1 coupler for a 4.3 in excellent condition...$50.00
1 flywheel for a 4.3...$40.00
2 thermostat housing from a 502 with 2 ports out...$40.00 each
2 thermostat housings with 4 ports out...$50,00 each
1 MK-4 timing cover $10.00
2 trailer springs...new never used for 2500# axles...$25.00 each
I will have more stuff as I dig it out.
Yes… I have six or seven distributors for V8 Chevy with two or three of them having the ECM with them. I think maybe one or two still has the stock thunderbolt wires also. All used distributors are all thunderbolt… Some are out of 454's and some out of 502's.
@motor... I do, I can't even tell you the goofy ass rigged up crap I have going right now just to get the engines started. NO WAY I want to run under open throttle with what I pieced together from home depot! LOL
Also thanks for your 2nd response
