PCV Hose question
Hi Guys,
Quick question for you, maybe you can help. I have a 502 MPI that was rebuilt last season and has 21 hours since rebuild. My question is... I have a PCV valve on the starboard valve cover that goes to an elbow under the intake manifold on the front of the motor. On the Port valve cover there is a plastic elbow with a hose that runs to the side (back) of the Spark arrester. The other day I smelled a burnt oil, popped the hatch and this line was off laying on the intake manifold, I put it back on with a clamp, but didn't tighten it too much because I didn't want to break the nipple which is plastic. Well I smelled it again the next day, and the hose blew off again. Should I just torque down the clamp and call it good? Or is this an indicator of a bigger issue? The motor was built by a reputable shop in Sandusky Ohio, so not sure what could be wrong. Oil smell is only 3/4 to WOT. Under that... No issue.
Also not sure of this is linked... But the starboard exhaust was steaming the whole weekend, but the port was not at all. Engine temp was normal, and it had done this every time out this year.
