Repair bad ECU V6 MPI PCM 555 >
Old 06-27-2016 | 04:01 AM
evaluex's Avatar
Default Repair bad ECU V6 MPI PCM 555
Ecu from my engine is out of order. I still can read memory and fault codes , do diacom tests etc but no ignition. No spark at the plugs . I remplaced ECU from friend's engine, and it fired up right away. Can it be repaired ? Or someone has spare one?
It's a MOTOROLA ECM0402, serial 892204, 09-28-2004
evaluex is offline
Old 06-27-2016 | 05:02 AM
Whipple can repair them depending on what's wrong with it. They fixed a broken pin in mine and it works fine now. If I remember right it was $400
jdflchr is offline
Old 06-27-2016 | 06:20 AM
the ecu needs to be opened up to see whats failed.I have a 555 that I use to rob parts out of.
can you open the ecu up and take some pics?
sutphen 30 is offline
Old 06-27-2016 | 03:55 PM
evaluex's Avatar
I already mailed dustin @ whipple twice but no response ...
Not being specialist in ECU's Not my best option to open it myself ...
evaluex is offline
Old 06-27-2016 | 07:52 PM
+1 Whipple, they fixed my IAC chip
Mseuro is offline
Old 01-24-2017 | 11:40 AM
evaluex's Avatar
He fixed it again
evaluex is offline
Old 05-01-2020 | 11:00 AM
Default Pcm 555 opening
hello......any chance this thread is still alive?
Can you tell me how to get the pcm-555 case open?
I'm bending it all up.....
Thanks- jim
Ajayallen is offline
Old 05-01-2020 | 11:08 AM
BUP
MAN THEY HATE WATER TO.
BUP is offline
Old 05-01-2020 | 11:13 AM
BUP
BUP is offline
Old 05-01-2020 | 11:17 AM
BUP
they hate a big voltage spike as well.
You have little by little pry all around the case to get them to open. What are trying to do ?
BUP is offline
