Stellings parts needed >
Old 06-29-2016 | 02:31 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Default Stellings parts needed
So I'm screwed unless I can locate these obsolete parts. I am in need of the drive shaft companion flanges that connect the drive shafts to the pillow blocks in the Stellings extension boxes. I wore the splines out in mine and of course they are no longer available since Stellings is belly up for some time now. I'm hoping someone has some laying around that they will part with or knows a good machinist who can duplicate these for me?
fireboatpilot is offline
Old 06-29-2016 | 02:34 PM
14 apache's Avatar
Originally Posted by fireboatpilot
so i'm screwed unless i can locate these obsolete parts. I am in need of the drive shaft companion flanges that connect the drive shafts to the pillow blocks in the stellings extension boxes. I wore the splines out in mine and of course they are no longer available since stellings is belly up for some time now. I'm hoping someone has some laying around that they will part with or knows a good machinist who can duplicate these for me?
call stellings i think they will still sell some parts for the boxes.
14 apache is offline
Old 06-29-2016 | 02:38 PM
RIPSTA Racing Team
Here's the number I have for them, 559-485-2842. Called them and she said no parts are available anymore
Old 06-30-2016 | 05:13 AM
Zieger is making there boxes now.
Black Baja is offline
Old 06-30-2016 | 07:31 AM
RIPSTA Racing Team
Do you have contact info for Zieger?
Old 07-01-2016 | 07:12 AM
419-621-7770 Everett performance/ Zeiger Steering.
Old 07-06-2016 | 08:05 PM
RIPSTA Racing Team
Zeiger is NOT making parts for the Stellings boxes. They only took over the steering line. Nobody is doing the stellings boxes. After some extensive searching I found a guy in Wisconsin who says he can make the flanges I need for about $650. each. I sent him everything to him, I'll keep the result posted. If it wasn't for the infinite wisdom of mercury using a 17 spline on the input shaft I could have bought them off the shelf.
Old 07-07-2016 | 12:14 AM
northernoffshore's Avatar
i have a speedmaster line drive carrier ???
northernoffshore is offline
