Tow/truck/trailer wiring >
Old 07-05-2016 | 02:02 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Tow/truck/trailer wiring
Two separate items, sold as a lot. I bought these to get a setup working on my GF's SUV, and did not end up needing them.
New-Pollak-7-Way-Pole-Trailer-Connector-Plug-Pin-in-Center
New Pollak 11-898 RV 7 way OEM Socket & Wiring Kit With Bracket
4' long, this is for the truck side of your setup, ideal to replace broken trailer wiring, OR to relocated your hitch wiring connector into the rear bumper beside the license plate like most folks do when upgrading hitch. You may not even need the wiring pigtail to do this.
[ATTACH=CONFIG]556982[/ATTACH]
[ATTACH=CONFIG]556983[/ATTACH]
[ATTACH=CONFIG]556984[/ATTACH]
[ATTACH=CONFIG]556985[/ATTACH]
[ATTACH=CONFIG]556986[/ATTACH]
[ATTACH=CONFIG]556987[/ATTACH]
[ATTACH=CONFIG]556988[/ATTACH]
$40 shipped using USPS flat rate box
Attached Thumbnails Tow/truck/trailer wiring-s-l1600.jpg   Tow/truck/trailer wiring-s-l1600.jpg   Tow/truck/trailer wiring-s-l1600.jpg
Sydwayz is offline
Old 07-05-2016 | 02:22 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
This is how you can mount the female side in the rear bumper of your truck. This is on a 2500HD GM, whereas the original trailer hitch wiring location is low, weak, and vulnerable.
You can also use all this for a 5th wheel or gooseneck extension if needed.
[ATTACH=CONFIG]557004[/ATTACH]
Attached Thumbnails Tow/truck/trailer wiring-img_7219.jpg
Sydwayz is offline
Old 07-11-2016 | 07:05 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Make offer.
Sydwayz is offline
Old 08-01-2016 | 08:55 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
bump
Sydwayz is offline
