Sea strainer bolts tight!
Old 07-07-2016 | 09:24 AM
Default Sea strainer bolts tight!
I would like to clean my sea strainers. The 1.5" bolt on the top is absurdly tight. No go with a normal socket wrench. I'm thinking big breaker bar but I'm afraid it will live up to it's name. WTF? Both sides same deal.
Let r buck is offline
Old 07-07-2016 | 12:14 PM
hblair's Avatar
May be time for the smokewrench.
hblair is offline
Old 07-07-2016 | 03:00 PM
Boat owner told me there is a small paper clip thick piece that you pull down and turn 90 degrees to unlock. Far away from it now so I can not investigate. Anyone know what he is talking about?
Old 08-01-2016 | 06:00 PM
For the record if someone has this problem, on mine it is a spring loaded pin that needs to be pulled down. The cover has a bunch of holes in it and you tighten by hand until snug, release the pin, then go a little more until the pin finds the next hole. It was not tight at all, pin was holding it. It was the 1.5 inch bolt on top that had me thinking it was probably just tight when I didn't know how it worked.
