Liquid speedometer >
Liquid speedometer
Liquid speedometer
Old 07-07-2016 | 08:29 PM
Default Liquid speedometer
My speedometer is ~95% full of water. I assume that unlike a compass that this is unintentional? How would water be getting into this (and how do I get it out)? as the top center gauge I could see it first in line to catch drips, but I have not yet found anywhere that water could have crept in?
scottgjerdingen is offline
Old 07-07-2016 | 08:36 PM
Tinkerer's Avatar
If it is a pitot tube style speedometer than I would say it has an internal water leak. I am assuming this is the case. Buy a GPS model.
Tinkerer is offline
Old 07-08-2016 | 04:05 AM
camptappakeg69's Avatar
I believe the liquid is supposed to be there, my tantrum has a liquid filled gaffrig speedo.
camptappakeg69 is offline
Old 07-11-2016 | 09:18 PM
They were the hot ticket, when I still had hair, now they're like 8 tracks!
509 SC is offline
Old 07-12-2016 | 01:16 AM
They are purposely filled with glycerin to prevent needle bounce. They have a little bit of air in them for expansion.
Griff is offline
Old 07-12-2016 | 11:17 AM
madbouyz's Avatar
Without knowing the Make and Model (year would help too) of the speedo , picture would be even better , there is no generic answer to the question .
I have two speedos in two different boats that if they had water in them they would have to be replaced . In that instance a perforated pressure sensing diaphram would be suspected.
However , some other speedos , namely the higher end models , do have what looks like water in them and it's supposed to be there . .
So exactly what are you dealing with ?
madbouyz is offline
Old 07-12-2016 | 12:57 PM
Oh, I thought a liquid speedo was like when my buddy opens a beer right as i'm coming on plane. If it stays in the can, you're not going fast. If it sprays out everywhere, you're going fast.
Wasted Income is offline
Old 07-12-2016 | 08:55 PM
bck's Avatar
bck
Charter Member#568
The dash is soggy/ leaking and the float switch in the speedo is broken.
Straight bottoms and flat decks
bck is offline
Old 07-13-2016 | 05:05 AM
My 96 scarab had a liquid filled speedo.
indysupra is offline
