rapidly fluctuating temp gauge - SBC >
Old 07-12-2016 | 11:32 AM
Default rapidly fluctuating temp gauge - SBC
I'm hoping someone can point me in the right direction. Last Saturday had the boat out and everything was going great. While cruising home I looked down and the starboard motor was running VERY hot (220+) so I instantly shut it down. Luckily I had twins so getting back to the dock wasn't an issue. Occasionally I would start it up to try and circulate some freshwater through the engine but could never get the temp to drop.
The boat is new to me as of a month or so ago so I initially thought it was probably just the impeller in the drive (Alpha SS) so last night I replaced it. While tearing it down I found some fresh sea weed in the pickup ports which leads me to believe that was the initial culprit of the overheating. Went ahead and replaced the impeller anyways while I had it apart. Put everything back together fully expecting to have fixed the issue and I would be good to go. Started the boat up and now the temp gauge is fluctuating very rapidly. I took a video and posted it here to show what I am talking about. Sorry about the quality. It was getting dark and I only used my cell phone. when the gauge is straight up its roughly on the 200 mark.
https://www.youtube.com/watch?v=LuIuGCjzebI
I swapped temp sender with the port motor and got the same result. Also swapped gauges without a change as well. I then back flushed the oil cooler thinking it might be clogged restricting the water supply but everything was nice a clear.
Before this the motor was rock steady at 150 degrees. Has anyone had a similar issue? Any ideas before I just start throwing parts at this thing? I plan on doing a compression test later this afternoon after work and hoping for the best.
JimNut is offline
Old 07-12-2016 | 12:13 PM
Is that in the water or running on a hose????
Griff is offline
Old 07-12-2016 | 12:35 PM
SB
I've never seen a temp guage move faster than a tachometer. LOL.
SB is offline
Old 07-12-2016 | 01:14 PM
I tried both. First go around was on the hose but then I filled a large tote with water past the pickups and just let the hose overflow the tote. no difference between the two.
JimNut is offline
Old 07-12-2016 | 01:15 PM
Me either haha! I'm hoping its something relatively simple but I'm starting to think that might not be the case...
JimNut is offline
Old 07-12-2016 | 01:25 PM
I have.
It was a puked head gasket on my 05 Duramax. Combustion gas in the coolant will make the needle whack. lol.
EDIT: It only did it at peak torque though....just enough cylinder pressure to push that much exhaust past the gaskets I guess.
Wasted Income is offline
Old 07-12-2016 | 01:37 PM
SB
Probably what it is with it seeing those temps.
I have seen many headgaskets push the temps up somewhat fast, just not that fast.
SB is offline
Old 07-12-2016 | 01:39 PM
My EGTs were pretty high at the time...rolling into it pulling my boat with a tuner installed. lol. The first few times it happened, the needle moved so fast I thought for sure it was a wiring issue...."no way could the temp be raising that fast". Found out that wasn't exactly true. ha.
Old 07-12-2016 | 03:17 PM
This was the answer that I was hoping not to hear but kind of presumed it is the culprit. I will be running a compression check later this evening and will report back with what I find. Just hoping that I caught it in time and didn't crack a head...
JimNut is offline
Old 07-13-2016 | 01:46 AM
Debris can get hung up in the T stat and give pretty erratic readings too. Saw that with some broken impeller pieces years back.
Trash is offline
