Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Rubbing compound / wax what should I use? >
Old 07-14-2016 | 11:52 AM
KN
Default Rubbing compound / wax what should I use?
Hey guys I have a small area on the back of my boat where the paint is rubbed off about half the size of a dime, and there are a couple of scratches,not to deep. I want to touch up the paint and buff the scratches out. Should I try a rubbing compound? wax? what brand? I will try to post a picture.
KN is offline
Old 07-14-2016 | 03:52 PM
glassdave's Avatar
Neno the mind boggler
you'll probably need to do a bit of fine sanding, maybe one two and three thousand grit before buffing. I use a course compound like Totally Buff from Fountain of Youth or 3M has some course stuff to.
08 OPA High Points Champion
glassdave is offline
Old 07-15-2016 | 05:56 PM
buckknekkid's Avatar
heres the latest from our Buff Girl. 600,1000,1200,1500, 2000, 3M Compound, 3M Cleaner wax, and finally wax[ATTACH=CONFIG]557283[/ATTACH]
Attached Thumbnails Rubbing compound / wax what should I use?-20160701_105351.jpg
buckknekkid is offline
