TRS to Bravo Flywheel help >
Old 07-14-2016 | 09:48 PM
Rookie's Avatar
Default TRS to Bravo Flywheel help
I am going to bravos with. At the present time I use top mount starters.
To use bottom mount starters do I need to flip my flywheels 180*?
I have Gen V blocks. I don't know the internal vs external balancing stuff.
Rookie is offline
Old 07-14-2016 | 10:14 PM
you will need different flywheel,s.also need to know if engine is internal or externally balanced.
mike tkach is offline
Old 07-14-2016 | 10:19 PM
Just need to move ring gear to block side of flywheel. Machine shop can do it or you can do it yourself .
PARASAIL941 is offline
Old 07-18-2016 | 10:48 PM
Rookie's Avatar
Bingo! Pulled one of the engines today. Flywheel is already machined to accept a ring gear on either side. This should be easy.
Rookie is offline
Old 07-19-2016 | 02:17 PM
yes they are all designed for engine side, few for rear, heat with large heating tip and switch right over
ezstriper is offline
Old 07-19-2016 | 08:15 PM
I've never removed a ring gear. Can you detail the process a bit more?
NHGuy is offline
Old 07-19-2016 | 09:06 PM
Use a blunt nose chisel or air chisel and work your way around ring gear evenly until removed. To install , make sure flywheel is clean of paint and rust. Clean inner surface of ring gear.
To make things easier , you can cool flywheel in freezer or ice down. Heat ring gear in household oven ( if not super clean , gear will smoke up house) or heat with torch. With gloves of course , drop ring gear in to position on flywheel. Make sure its fully seated and your done!!! Takes about 1/2hr total time to change ( less if already clean) Good luck!!
Old 07-20-2016 | 09:34 AM
you should buy a lottery ticket today because you are a lucky guy,my #6 flywheels are only machined for rear mount starters.i would bet that someone machined yours prior to your getting them.
Old 07-20-2016 | 09:59 AM
using a std size torch set with a big heating tip, heat all around the ring gear will fall off, flip flywheel over heat ring gear again lay place till drops into groove let cool
Old 07-20-2016 | 11:29 PM
Rookie's Avatar
I agree. I assume they were front mount to begin with and someone machined them for rear mount.
Rookie is offline
