Finally stopping trim tab pump leaking
Even bought leak proof caps. (Not). Walk into performance marine with my caps. And with in 2 minutes Jason and Rick came up with a fix and handed me a few parts. No more puking caps[ATTACH=CONFIG]557282[/ATTACH][ATTACH=CONFIG]557282[/ATTACH]
Shouldn't matter. There is still air in the resvoir tank anyway. The fluid is sucked from the bottom of the tank. Only way to suck air into the pump is if a hose breaks in the tank or you run low or out of fluid.
Problem was. They are mounted on the front engine room bulkhead. Caps are on the low side. You have to fill almost to the cap so you would suck air. Tested it this morning. Works great. Not a drop anywhere
http://www.ebay.com/itm/Genuine-MerC...VVn9nd&vxp=mtr
not sure if you guys know but merc has a updated cap,they have been working great on my boat,just a FYI.
