Silencer Tip Help
I am purchasing a 2005 Baja 25 Outlaw with Corsa's silencer tips for exhaust. I want to remove these exhaust tips and replace them with open pipes. Looking for some one who have removed them before to tell me what is involved. It looks like three bolts go thru the transom and are nutted on the other side. Did Baja use 5200 sealant to stick these on too? Or by chance is there a rubber gasket like some pipes I have seen. Any advice is appreciated.
Remove the screws and see if there's any wiggle room. If there on with 5200 which I kinda doubt good luck. Just try and see if they knock loose with a rubber mallet while tapping all the way around the tip. Just don't get to to aggressive in which case they are on with 5200. You'll risk pulling the gel off with mufflers. Piano wire etc and try work your way around the flange.
