Tripple engines / drives: >
Old 07-18-2016 | 12:37 PM
Default Tripple engines / drives:
Is raising any one of the drives out of the water, while the other two are running/working, a problem?
If one engine stops can that drive be raised to eliminate drag,or does that cause a problem?
Maybe a better way to phrase it: Are the drives designed to raise from the water independently while the other two continue to operate and drive the boat?
FlaTider is offline
Old 07-18-2016 | 03:51 PM
From: Central Square & Fishers Landing, 1000 Islands NY
Leave it dragging. You will put too much strain on the tie bars doing that. I have run mine on two motors more than once due to various issues and it will get on plane easy if you just drop the tabs and go. I have got on plane using both rear motors and using port and center motors no problem. Trim all the drives the same.
1000 islander is offline
Old 07-18-2016 | 04:51 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Your best bet would be to remove the prop, and continue on as normal, or as close to such.
Sydwayz is offline
Old 07-18-2016 | 06:07 PM
Thank you! First hand experience is Awesome!
FlaTider is offline
