1998 baja 272 502mpi top rpms
I'm fairly new to boat this big was told when I bought it that it would to 60 + at 5000 rpms but the fastest all trimmed out I can get is 54 at 6000 rpm the prop is a 23p any help is appreciated
+1, and it will run several MPH faster with that power. Sounds like you've got several things to check, tach being the first on the list. You may also be experiencing high slip or blow out from over trimming. That wheel is easy to blow out. Get some accurate numbers i.e. GPS speed @ RPM starting at planing speed and every 500 RPM up to WFO.Then we can calculate prop slip and get an idea.
