Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's >
Old 07-20-2016 | 01:45 PM
Full Force's Avatar
Default Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's
Bought a boat for some spare parts.... parting boat out it's rotted... runs and drives fine and can hear run until I pull engines....Always Freshwater..Lake Erie
Prices are based off my internet going rate and what selling prices are, not asking... I spend time to research and be as fair as I can be, and willing to deal within reasonable margin..will ship smaller items but big things like drives, engines and trans, are Pick up only, I will hold things with deposit ONLY and must be picked up within 2 weeks or less or whatever I agree on.
GAUGES AND PROPS NOT FOR SALE. I will remove parts/engines as things sell.
Text for videos of engines running... 440-476-4114
Located Olmsted Falls OHIO 44138
454 engines, Mark IV blocks,I think started as 370 mercs, have rectangle port heads, Aluminum intakes, and Holley carbs, no clue cams or power output I would assume 370-400, boat ran mid 63-65 depending on water conditions. carter fuel pumps, Eddie Marine flame arrestors, billet throttle brackets, fuel rails, braided lines, includes cooler and wiring, also Thunderbolt Ignition, No bell housing, trans, flywheels or exhausts..Starboard engine was redone 40 hours ago, I have paperwork for that to back it up, both engines build same.
Engines 2500.00 each complete turn key ready to go picked up
72C transmissions with lines and coolers 750.00 each
TRS drives RH/LH with nosecones, great shape, lowers look to be fairly new for sure no showers or props, 2000.00 each
GIL HP500 Exhaust with TRS tailpipes. 1500.00 a side or 2750 for all 4 plus ship
Outer transom assembly 400.00 each plus ship
inner plates 100.00 each plus ship
trim rams 300.00 a set plus ship
bell housings 100.00 each plus ship
trim pumps 125.00 each plus ship
exhaust tips 120.00 pair plus ship
Bennett tab setup with pump 250.00 plus ship
All parts in hull for sale for ScarabII BRAND NEW purple cockpit cover, compass, fridge, sink, lighting, rails, vents, all for sale... post needs
compass 100.00 plus ship
bolsters 400.00 P/U
Scarab cabin door 200.00
Bomar haches 150.00 each
stereo stuff is all Kenwood marine may sell as complete stereo.ask...
Trailer will be for sale later when hull is gone..
[ATTACH=CONFIG]557452[/ATTACH][ATTACH=CONFIG]557453[/ATTACH][ATTACH=CONFIG]557454[/ATTACH][ATTACH=CONFIG]557455[/ATTACH][ATTACH=CONFIG]557456[/ATTACH][ATTACH=CONFIG]557457[/ATTACH][ATTACH=CONFIG]557458[/ATTACH][ATTACH=CONFIG]557459[/ATTACH][ATTACH=CONFIG]557460[/ATTACH][ATTACH=CONFIG]557461[/ATTACH]
Attached Thumbnails Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's-p1019759.jpg   Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's-p1019760.jpg   Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's-p1019761.jpg
Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's-p1019762.jpg   Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's-p1019764.jpg   Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's-p1019765.jpg
Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's-p1019766.jpg   Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's-p1019767.jpg   Parting out 1984 Scarab II (Cleveland Ohio) TRS 454's 72C's-p1019768.jpg
Full Force is offline
Old 07-20-2016 | 04:13 PM
I am interested in several of the pieces.
I will try to PM you.
I am located in Sandusky.
Dan
DanWentworth is offline
Old 07-20-2016 | 06:42 PM
Full Force's Avatar
Thx bud
Old 07-21-2016 | 12:55 PM
does it have sea strainers?
mcprodesign is offline
Old 07-21-2016 | 01:17 PM
Full Force's Avatar
Yes perko brass ones 100. Each
Old 07-22-2016 | 04:41 AM
Full Force's Avatar
One set of exhaust sold, trim cylinders sold, outer transom assemblies sold...
Old 07-22-2016 | 09:30 AM
[QUOTE=Full Force;4462206]Yes perko brass ones . Thanks
Old 07-26-2016 | 09:26 PM
Hey I tried to send a message says your in
Box is full interested in the bolsters thanks
mbasile1982 is offline
Old 07-27-2016 | 03:59 AM
Full Force's Avatar
Bolsters sold..
Old 07-27-2016 | 11:12 PM
Hi,
Do the tips have flappers in them? Are the 4"?
monster12valve is offline
