2007 35 executioner prop question >
Old 07-23-2016 | 03:46 PM
Default 2007 35 executioner prop question
I'm in the process of buying a 2007 35 fountain executioner with 496 HO. it has 1.65 drives with a 32 5 blade. on the surveyed test drive it had full tanks with 3 adults. the boat only ran 72 mph at 4400rpms WOT. the drives were at 4.5 and tabs at 2. is this normal with the 32 5 blade or does the drives just need to be trimmed higher. I was told it should run 78-80
shannon2100 is offline
Old 07-24-2016 | 08:33 AM
Call Fountain with the hull number and they will fax you the test run sheet that has the speed they achieved and the props used.
fordf350 is offline
Old 07-24-2016 | 11:25 AM
I already did that it had the bravo 4 blade 32 ran 79 at 5150. The prop has been changed to a 5 blade 32
Old 07-24-2016 | 08:53 PM
You are putting a tremendous load on those engines if 4400 is WOT , I have the same boat with the same motors and I had BBlades make a set of 34 Bravo 4 blades that are lab finished . The best I have seen is 80 @ 4950 and the tabs all the way up drives @ 5
Finney is offline
Old 07-24-2016 | 09:23 PM
I think all the Fountain reports are a little on the happy side,
I am new to the 35 EX myself,but talking with other 35 owners I have been told the boat is a true 75MPH boat and when all the planets and stars line up that one day you might see a honest 80, but expect 75,hopefully I am wrong and with the right props we might see 80.
boatnt is offline
Old 07-25-2016 | 08:14 AM
I'm not worried about the speed I guess what I'm asking is should I be able to turn 32 5blades closer to 5000rpm or when you go to 5 blades do you need to go to 30's
Old 07-25-2016 | 11:08 AM
Can you ask the previous owner why it had 5 blades on it? The 32 four blade props are the correct ones for the boat with a 1.65 ratio. Sounds like the 5 blades were an attempt to improve mid-range speed, but certainly not top end. As you can see with the 5 blades and all that weight on the test run, the engines didn't have the steam to deal with the load. You would have to drop pitch on the 5 blades to get closer to the proper WOT for those engines. I'd go back to the 4 blade 32 Bravo 1's as that is the perfect prop for the 35 Ex. I've been in 3 different ones and they all ran 32 four blades with 1.65 drives. Depending on gear, fuel, persons on board you should see 76-78 at WOT of about 5000-5100. A stock 35 Ex with 496's is not an 80 mph boat.
techman is offline
Old 07-25-2016 | 11:18 AM
techman is right on the money here. Spot on with the info he has put out for you.
The tall gear boats were a tick faster on the top end, did give up some in getting there vs the 1.50 geared boats.
RaggedEdge is offline
Old 07-25-2016 | 11:35 AM
He said it was running on the limiters and he wanted a better cruising speed.
Old 07-25-2016 | 01:21 PM
That's what I thought. Propping is always a compromise!
techman is offline
