Go Back  Offshoreonly.com > Owners Forum > Saber
What prop works best on a single 28 saber >
Old 07-25-2016 | 09:39 AM
Default What prop works best on a single 28 saber
Hi I'm trying different props should I use a LH or RH I 700 hp 1,50 bravo ITS
drjoe33 is offline
Old 07-25-2016 | 09:52 AM
Call Doug at the factory, he'll point you in the right direction
jbraun2828 is offline
Old 09-16-2016 | 04:58 PM
Post some pictures of the boat!
slpcamaross97 is offline
Old 10-27-2016 | 01:51 PM
AIR TIME's Avatar
how did the boat run????????
AIR TIME is offline
Old 10-27-2016 | 02:02 PM
AIR TIME's Avatar
What is your x or how far is your prop shaft below the boat 4 1/2'' 5'' 5 1/2'' hope not anymore than that?? if your x is 16 to 17 try a 26 or 28 bravo 1. if your higher 17 to 18 try a 5 blade. if your getting good bow lift px 5 if to much like me a p5. I run 32s 5and 4 blades. if you porpoise a lot and drive is tucked under tabs down loose the gas tanks in the bilge.
AIR TIME is offline
