speed gain
SubscribeOn average how much speed can be gained with 2" shorter drives? I realize there are other variable's so this is a bit of a generic question, thanks for any info.
getrdunn
close
- Join DateFeb 2009
- LocationNW Michigan
Liked:1,515 Times in 824 Posts
Lot of variables. Boat make, step-nonstop, pad-nonpad, length, weight, power, current X dim etc. Just list what your up to and I would imagine someone here on the board has perhaps done so on same boat and will have first hand experience with.
Griff
close
- Join DateOct 2000
- LocationOmaha/LOTO
Liked:2,523 Times in 1,259 Posts
0-5 mph depending on many factors.
Completely depends... My boat gained 2mph buy adding a spacer (opposite of a -2 lower)
Prop shaft 9" below bottom of boat 650hp non step 70 mph at 5600rpm . Just looking for a more.
endeavour32
close
- Join DateMay 2009
- LocationChicago, IL; Onekama, MI
Liked:124 Times in 69 Posts
That is really deep. I would think that would would see some increase from a shorter lower. What boat do you have? Your specifications are too vague for us to give you any real answer, but I do think 9" is extremely deep though.
32' envision , twin 650's
endeavour32
close
- Join DateMay 2009
Even with 2" shorties you're still 7". If I were you I would get a set of -3's. You will need to modify your Bravo upper but it can be done. Tinkerer has done this, maybe reach out to him for advice on this.
What kind of speed are you getting now with your current set up?
SB
close
- Join DateNov 2004
- LocationOn A Dirt Floor
Liked:3,729 Times in 1,704 Posts
Quote:
Poor fish.Originally Posted by lskaracing
