Go Back  Offshoreonly.com > Owners Forum > Powerplay
Fuel Tank Location >
Fuel Tank Location
Fuel Tank Location
Old 08-07-2016 | 06:46 AM
Default Fuel Tank Location
I have two fuel fills on my 33, where are the 2 tanks located? The engines are moved forward because of the transmissions, if that makes a difference.
ezrizer is offline
Old 08-07-2016 | 07:49 AM
Their right below the cockpit floor. If you unbolt the cockpit center section and take it out you will have plenty of access to both tanks. You should also be able to see them by removing the small circular access panel in the middle of the cockpit floor.
272bajadriver is offline
Old 08-07-2016 | 09:18 AM
Thanks. I did some additional checking and it appears that the the two tanks are port and starboard rather than one in front of the other?
About 95 gallons each?
ezrizer is offline
